Softlines on a sapphire cosworth
Hi all.
just tried fitting my new softlines on my sapprire and the front wheel snags the caliper.any fix for this.7.5x17.et38.spacers front and rear ?
Hi There
I had the same issue on my 2wd Sapphire Cossie with ford 17inch diamond cut alloys, they were rubbing the front brake caliper and had to put 5mm spacers on the fronts to clear them and its been fine for the passed 10 years. I was told you told you don't get this issue on the 4x4 sapps.. Hope this helps.
Indy
Indy
Damian Davy
Jun 6, 2020 08:58 PM
