4x4 front diff tag identification
Old Jul 16, 2020 | 03:48 PM
christos's Avatar
christos
10 Year Member
Default 4x4 front diff tag identification
Hi guys, I have a front diff which write on the tag
V90BB AA
C9P5A OM17
Is this a 3.92 diif?
Regards
Old Jul 16, 2020 | 09:29 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Easiest way to check is to count the turns. Mark one of the output splines and then turn the input flange and see how many turns it takes to rotate the output one turn. If it's about 4 turns, it's a 3.92, if it turns about 3 1/2 then it's a 3.62. There aren't any other stock ratios available so it should be pretty obvious which one it is. If it's only about 3 turns, I'll take it off your hands.
Old Jul 17, 2020 | 11:13 AM
christos's Avatar
christos
10 Year Member
Ok,thank you
Old Jul 23, 2020 | 03:24 PM
shark91's Avatar
shark91
Hi mate ,
it's written inside the 13/51 crown. Divide 51/13 = 3.92 :sourire:
Rob Virgo
13
Oct 28, 2011 10:24 AM
robrs2
Feb 10, 2008 10:57 PM
raggey
Mar 7, 2006 06:19 PM
JohnnyB
Apr 21, 2005 06:19 AM
