Spot lamps
Can anyone tell me where spot lamp loom connects to original loom please on my s2 rs turbo, 90spec.on my 90spec xr3i theres a connector by header tank, but there isn't on rs turbo
A factory RST should have the connections already built into the main loom that routes around the engine bay. To find where it connects in you'd have to strip all the protective tape that binds it together.
The connectors to the lamps should be bullet connectors - they are on my 90 spec and that's what the spot lights take (Carello 640s).
