MK2 Focus Aircon
Old Jun 17, 2020 | 06:05 PM
iansoutham's Avatar
iansoutham
OCD Victim
Default MK2 Focus Aircon
Does anyone has knowledge of aircon wiring diagrams for a MK2 Focus about 2006?
Have one here where there is gas in the system but the aircon does not work. Bridge the relay in the engine fuse box for the pump and it runs. Switch is working and confirmed on my Foxwell diag tool and has a new high pressure transducer switch as the old one was leaking.
Old Jun 20, 2020 | 10:49 AM
iansoutham's Avatar
iansoutham
OCD Victim
Anyone? Any ideas welcome....
Fan switches on after a few seconds when ac button pressed and have confirmed 600g of gas in the system and no leaks (passed vac test and uv dye).
Have got Ford IDS but it does not show anything to do with the aircon system other than the switch supply.
All fuses that I can find are good so it looks like the switching supply through the pump relay is the issue.
Daveysaff
May 18, 2012 09:22 PM
woolford
Ford Focus RS
Apr 21, 2011 03:38 PM
