Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
PCM location MK2 Focus
Old Jun 11, 2020 | 10:40 AM
scallywag's Avatar
scallywag
Default PCM location MK2 Focus
Hello everyone, new to this Forum due to not being able to find the PCM in my 06 MK2 Focus 1.6 Sport Estate. Had the Instrument Cluster pack up again and was told by an auto electrician to check the 2 Plugs that go into the PCM and that i,d find it behind the Glovebox, well, i,ve had all the inner Glovebox out and can't see it in there, does anyone have any suggestions as to where i,m likely to find it, many thanks for reading.
Old Jun 11, 2020 | 12:32 PM
focusv8's Avatar
focusv8
According to this, under the left front wheel arch liner;
https://passionford.com/forum/ford-f...-location.html
Old Jun 11, 2020 | 04:05 PM
scallywag's Avatar
scallywag
Thanks for that. Had a look behind the Arch liner (front Bumper side) and all i could see was a black Plastic cover but with 1 Hex Bolt which looked like it was connecting it to the Bodywork, there were no other Screws so i don't think that could have been it !!
Old Jun 11, 2020 | 06:35 PM
GVK.'s Avatar
GVK.
It's definetly behind the front bumper left hand side, there's a security torx bolt or bolts that you have to cut a slot into to remove.
I posted on the other thread
Originally Posted by GVK 8 yrs ago
Take out the left front wheel arch liner, then there's another plastic cover with torx screws behind the edge of the bumper.
Might be a shear bolt on the metal security cover on the ECU, I just cut a slot in them with air-cut off tool and undo with screwdriver.
3doorcozmess
Jun 17, 2012 07:41 AM
dj0nes
Mar 25, 2010 12:55 PM
