ST170 Front Suspension Overhaul - Parts missed??
Old Jun 9, 2020 | 10:30 AM
rupes1351's Avatar
rupes1351
Default ST170 Front Suspension Overhaul - Parts missed??
Hi,
Just bought an ST170 and am planning on overhauling the front suspension - shock and coil spring fairly new already. Brakes need doing and it doesn't feel very tight, vibration under hard braking etc. I am trying to get together a list of parts I should replace. So far I have this list - am I missing anything that should also be done at the same time? Hoping this will tighten it up.
- Brake Pads, Discs
- Lower Control Arms
- Inner tie road & tie rod ends
Thanks,
Rupert
Old Jun 9, 2020 | 12:16 PM
focusv8's Avatar
focusv8
Anti roll bar drop links.
Westy
11
Mar 9, 2005 07:27 PM
