First go at tig welding
Old Jun 9, 2020 | 09:36 AM
mk1turboestate's Avatar
mk1turboestate
Default First go at tig welding
Morning all, I ended up buying a rally design tig welder, a bottle of argon and some consumables, I haven’t tried to weld aluminium yet because the instructions are not particularly clear on what all the knobs do!
I filmed my first welding job of filling a couple of numbers plate holes on my metro, any advice is appreciated
Old Jun 9, 2020 | 10:11 PM
PAUL V's Avatar
PAUL V
Hold the torch like a pencil between your thumb and finger,
Make sure you have your leads on the right way around the earth clamp goes to + when tig welding.
Maybe post a photo of your connections
Old Jun 10, 2020 | 04:50 AM
dan le moignan's Avatar
dan le moignan
Also keep your arms covered as like most welding TIG gives off UV rays
Old Jun 10, 2020 | 08:15 AM
Johnny Knoxville's Avatar
Johnny Knoxville
Torch angle.. Try to keep a 70 degree to the surface and add the filler at a 20 degree ish
Old Jun 10, 2020 | 11:26 AM
mk1turboestate
Cheers all, here are the knobs on the front
Old Jun 10, 2020 | 03:53 PM
essy's Avatar
essy
What diameter filler rod were you using?
Old Jun 11, 2020 | 08:44 AM
mk1turboestate
I was using 2.4, I understand that on a thin panel it should have been thinner but I didn’t have any,, building up the consumables stock is on the list
GVK.
16
Sep 23, 2013 05:24 AM
GVK.
11
Aug 25, 2013 12:16 PM
B16
23
May 27, 2013 02:15 PM
