No earth pulse to injectors
Old Jun 6, 2020 | 03:24 PM
Darren-cosworth's Avatar
Darren-cosworth
Default No earth pulse to injectors
Anyone else had this problem, 2wd sapphire cosworth
im getting no signal earth from ecu to the injectors .
checked the live coming in to ecu and has a good earth coming into it.
Old Jun 6, 2020 | 03:50 PM
james kiely's Avatar
james kiely
Have you checked your phase sensor in your dizzy
Or reset the phase sensor
Old Jun 6, 2020 | 05:14 PM
G22cossy's Avatar
G22cossy
Checked phase sensor
Old Jun 7, 2020 | 05:07 PM
martysmartie's Avatar
martysmartie
Power to injectors?
How have you determined that they are not being grounded?
Martin
Old Jun 7, 2020 | 06:36 PM
G22cossy's Avatar
G22cossy
Originally Posted by martysmartie
Power to injectors?
Martin
they have a live on the ignition but no earth signal from ecu on the cranking
Old Jun 7, 2020 | 06:40 PM
martysmartie
Then as said, you need to check the phase sensor output.
A common issue here can be the wides go brittle and short out.
Martin
Old Jun 7, 2020 | 06:48 PM
G22cossy's Avatar
G22cossy
Check the output on phase sensor
Old Jun 13, 2020 | 10:15 AM
Darren-cosworth
new crank sensor, phase sensor, ecu changed.
Still no earth signal to injectors 🤦‍♂️
Old Nov 28, 2021 | 04:26 PM
3898jake's Avatar
3898jake
Hi Darren
Im having the same problem with my cosworth at the moment, did you ever get to the bottom of it ?
Thanks Jake
MADMAXPTT
Mar 15, 2015 09:20 AM
bigkev
Dec 3, 2010 05:13 PM
rich123
Aug 22, 2009 07:17 AM
