2.3 granada scorpio
Old May 31, 2020 | 07:00 AM
Paulmcd's Avatar
Paulmcd
Default 2.3 granada scorpio
Hi, new here, project using granada engine, anyone help with diagrams off wiring looms or ecu with pats system, or can it be done thanks for any help
Old May 31, 2020 | 10:13 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
try fordscorpio.org, you may find something there. to use an ecu with pats you'll need the key to match the ecu, the ring that goes around the ignition barrel and the associated wiring. big_wasa on here also may be able to help, he loves playing with standard looms and ecu's
Old May 31, 2020 | 11:03 AM
Paulmcd's Avatar
Paulmcd
Thanks mate
Old May 31, 2020 | 05:54 PM
big_wasa's Avatar
big_wasa
Is it a Granada or the Scorpio ? I would have thought the granny was pre Pats ?
is it a 60 pin ecu or the 104 pin ?
Old May 31, 2020 | 06:44 PM
Paulmcd's Avatar
Paulmcd
Scorpio with a 104 pin thanks
Old May 31, 2020 | 06:54 PM
big_wasa's Avatar
big_wasa
I can’t tell if the Scorpio is internal or external Pats.
have you got the wiring loom ? You would need to cross reference this with the loom.
Scorpio
4) Abs
6) Pats
8) Pats
11) Pats
13) Dlc
14) Heated windscreen relay.
15) Dlc
16) Dlc
17) Engine coolant relay.
19) Pats.
20) Inj 3 Black / blue.
21) Crank position sensor. Brown / red.
22) Crank position sensor. White / red.
24) Earth.
25) Earth.
26) Coil cyl 1+4
27) Pats
30) Octane plug.
31) PSP.
34) Baro / map sensor.
35) O2 sensor white.
36) Maf Brown / blue.
38) Ect.
39) Iat.
40) Fuel pump monitor.
41) Ac pressure switch. Purple / orange. Thanks
42) Pats.
43) Trip.
44) Air solenoid white.
47) Egr Black / green.
48) Taco white / Black.
51) Earth.
52) Coil 2+3
53) Pats.
54) Fuel pump relay control Black / blue.
55) kam ( permeant live ) orange.
56) Evap Black / orange.
58) Vss white.
60) O2 pre cat signal.
64) Cpp.
65) Egp.
68) Coolant fan relay.
69) Ac clutch relay. Black / green.
70) Inj 1 Black / white.
71) Switched live. purple / orange.
73) O2 post cat heater circuit.
76) Cam shaft Brown
77) Earth.
83) Iacv Black / green.
85) Camshaft white / purple.
86) Ac pressure switch. Black / orange.
88) Maf white / blue.
89) TPS.
90) 5v out.
91) Sensor balanced earth.
92) Bpp.
93) O2 pre cat heater circuit.
95) Inj 4 Black / orange.
96) Inj 2 Black / green.
97) switched live Purple / orange.
100) O2 post Cat heater circuit control.
103) Earth.
paul302289
Aug 1, 2012 09:52 AM
10pluggen
Technical essay Archives
Jun 1, 2012 04:13 PM
robinhood
Dec 27, 2008 02:12 PM
the saint
Feb 15, 2008 12:21 AM
