MK1 Escort clock upgrade
Old May 3, 2020 | 05:25 AM
Foeg2007's Avatar
Foeg2007
Default MK1 Escort clock upgrade
Hi. Just joined this forum as I have purchased a MK1 that's been restomodded. There are still things to finish but a pressing issue for compliance is getting all the dials to work with a new Zetec on throttle bodies. What I'd like to do is replace the gauges with modern items but still retain the classic six dial look. Apologies if this has been asked multiple times in the past but can the small gauges - water temp, volts, fuel and oil pressure be replaced with modern dials and where best to get them from? Most auxiliary gauges come in 52mm but the original ones are smaller, about 45mm. I see there is a replacement panel available complete with gauges but want to retail the original look. Appreciate any advice since I'm a newbie at this. Cheers
Old May 3, 2020 | 08:21 AM
Mark V8's Avatar
Mark V8
Your car looks mint
Turbosport would be a good place to ask, I member this thread from a while back if you are gifted in electronics!
http://www.turbosport.co.uk/showthread.php?t=841615
Old May 3, 2020 | 10:22 AM
Mondi-DZK's Avatar
Mondi-DZK
Originally Posted by Mark V8
Your car looks mint
+1 need more pictures.
dangermouse
Jul 29, 2019 03:54 PM
tonysierra4x4
Dec 31, 2014 06:26 PM
johnnyspencer
Ford Classics & Vintage
Nov 11, 2012 03:33 PM
pee vee
Ford Focus RS
Mar 7, 2011 08:03 PM
bigrsjay
Mar 29, 2005 02:35 PM
