Mk4 Escort ST170 Conversion help
Old Apr 8, 2020 | 07:20 PM
craftsman1985's Avatar
craftsman1985
Default Mk4 Escort ST170 Conversion help
I'm starting my st170 conversion on my mk4 escort efi, I have all the mounts to do this and my enitial thought was to use the original bc gearbox fitted to the xr3i efi engine..... but on further investigation it would seem that I need a rear mounted starter gearbox to fit to the st170 engine. Is this true?
can you get a rear mounted starter bc gearbox or will I need to convert to an ib5 gearbox and is this a straight fit? I.e. Driveshafts, gear linkage and mounts.
Old Apr 10, 2020 | 02:17 PM
MK5 ESCORT's Avatar
MK5 ESCORT
Escort mk6 gti box is what i used.
You can use front start box if you shave the sump, sump will need shaving at the back too for drive shaft regardless of the box (unless you modify to fit the focus box then its a bigger job)
Old Apr 10, 2020 | 06:56 PM
gcfcos's Avatar
gcfcos
Lovely looking escort there
Skinnymcdee
Apr 4, 2020 04:31 PM
mondeomark
Escort Range
Jan 11, 2015 07:32 AM
mondeomark
Dec 28, 2014 12:51 PM
colincassar
May 13, 2013 03:40 PM
MadMac
Sep 11, 2004 05:13 PM
