3 door sierra brake problem
Old Apr 4, 2020 | 07:27 PM
cosworth323's Avatar
cosworth323
Default 3 door sierra brake problem
Looking for a wiring diagram for abs wiring on 87 sierra. I am having problems getting the servo pump running as there is no power going to it.
There was a problem with the pump and i changed it and can power it up when i bring a direct power to it. I seem to be missing a ignition live
to the abs relay so i would appreciate a wiring diagram if somebody has one. All i really want is the pump working so i have servo assistance .
Is there a way it can be wired up without having the ABS working.
Old Apr 4, 2020 | 07:58 PM
james kiely's Avatar
james kiely
Have you checked your relay is triggering ok
Old Apr 4, 2020 | 08:33 PM
cosworth323
Relay is not triggering and the relay is ok. It's missing the live to the relay that triggers it. Also have no live at the ecu so I'm assuming I have a wiring issue some place so could do with a wiring diagram.
3FRD
15
Dec 13, 2016 10:57 PM
E.D.S Engine & vehicles.
Nov 12, 2012 12:14 PM
cossie moon
Jul 24, 2012 10:04 AM
bods
Apr 4, 2009 09:11 AM
Dearo
Sep 1, 2008 08:46 PM
