Cossie rear poly diff mount.
Old Mar 17, 2020 | 08:33 PM
Default Cossie rear poly diff mount.
Just a quick on people.
I take it the bracket I've circled should be fitted to the diff side.
Old Mar 17, 2020 | 08:57 PM
Caddyshack's Avatar
Caddyshack
One either side of the bush so yes, one on the diff side
Old Mar 18, 2020 | 05:08 AM
Yeh I thought so thanks.
Old Mar 18, 2020 | 12:25 PM
The Youth.'s Avatar
The Youth.
one of the brackets should be countersunk for the countersunk head of the bolts
mine are
Steve
Old Mar 18, 2020 | 01:17 PM
dojj's Avatar
dojj
Resident Wrestling Legend
one set of holes looks much bigger than the other set
Old Mar 18, 2020 | 01:25 PM
The Youth.'s Avatar
The Youth.
there supposed to be, the bigger holes go over the metal sleeves on one side to compress the poly mount
steve
Old Mar 18, 2020 | 02:19 PM
mine are
Steve
Yeh mine came with Allen bolts and normal 17mm bolts. So I thought the bracket that wasnt counter sunk was used with the 17mm bolts.
D7AKE
Apr 19, 2009 06:07 PM
krisberic
16
Aug 2, 2007 02:43 PM
david
May 19, 2007 05:59 PM
Tony Ryan
Sep 11, 2006 12:22 AM
