Toe shims.
Old Mar 1, 2020 | 11:26 AM
carbon1993's Avatar
carbon1993
Default Toe shims.
Hi im looking for toe shims for my xr4i. Who still makes them? Ideally looking to get out 1 to 1.5 degrees
Old Mar 1, 2020 | 06:35 PM
Marc sierra's Avatar
Marc sierra
Do you mean toe or camber? Toe should never be in the range of 1 to 1.5 degrees....
Old Mar 1, 2020 | 06:50 PM
I've got a pair fitted to my saph. They have defo made a difference to how the wheels sits.
Old Mar 1, 2020 | 09:51 PM
carbon1993's Avatar
carbon1993
Definitly toe plates what i need. I am busy with making my own adjustable beam. But i guess i got suplied with the wrong arms.
So iam hoping some toe shims will do the trick
Old Mar 2, 2020 | 08:42 AM
After I fitted mine I can now tell that the wheels seems to sit more flat on the ground and isnt cleaning in.
Old Mar 2, 2020 | 10:52 AM
carbon1993's Avatar
carbon1993
are you talking about the toe or camber?
Old Mar 3, 2020 | 11:22 AM
Camber matey.
Old Mar 17, 2020 | 09:38 PM
carbon1993's Avatar
carbon1993
which ones do you have and how thick are they? and how much camber did they take out.
My camber is off also if i can get 1 to 1.5 degree camber out with that plate.
My toe is 4mm out to ..... mm out. Camber is around 2 positive to 1.3 negative.
If those plates are thick enough i think i can also regrind them to take out 3mm on the plate for the toe. then everything should be set .
Old Mar 18, 2020 | 05:13 AM
these are mine. Sorry I cant tell you how thick they are cause they are in the car. I just got mine off eBay.
Old Mar 23, 2020 | 07:26 PM
grcossie's Avatar
grcossie
Bilderesultater for camber shims cosworth
Rhys
Apr 22, 2009 05:02 PM
scottbrown
Apr 17, 2007 07:32 PM
