Escort mk6 1.4 lx
hi can someone help me I have a escort mk6 that I make it turbo with stand alone ecu and I took out the factory ecu with all the engine harness cause I don't need it anymore but now I don't have starter everything work ignition not starter I nhow because I took out the Pat's ring from the key all I need is changing the starter relay but can someone show me which or photos pls takes
fast fords
Dec 18, 2007 10:16 PM
Less.
Jun 17, 2007 01:18 PM
