Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
2004 tdci ghia focus drain fuel tank
Old Feb 6, 2020 | 12:24 PM
gagglelauren's Avatar
gagglelauren
Smile 2004 tdci ghia focus drain fuel tank
need to drain £45 of fuel ,suspension collapsed after I put in , may scrap so want to retrieve fuel , on fuel line push connect fitting in and out of component , I was told to connect to this drain pipe and turn ignition to point one and pump it out but the flow at that point stopped unless engine is running , engine will not get fuel to run anyway if disconnected .any clue welcome please. will try upload picture later of connections I speak of thanks
Old Feb 6, 2020 | 01:54 PM
gagglelauren
component i was hoping to drain tank from , unless engine is running no flow
Old Feb 6, 2020 | 08:41 PM
GVK.'s Avatar
GVK.
As far as I know threre is no lift pump in the tank so this method will not work, if you are going to scrap it just drill a hole in the tank and drain it out that way.
Or use a pump on one of the lines..
Old Feb 7, 2020 | 08:28 AM
gagglelauren
OK ,thanks for that will get them to take it with the fuel in it .
Hotblack
Ford Focus Diesel
12
Dec 28, 2017 03:29 PM
jonhunt85
Sep 11, 2013 07:02 PM
