Looking for a Cosworth 2WD engine loom
Do you mean a used one or brand new one? You have to remember any used one will be around 30 years old now with the potential risk of intermittent faults etc. If you can afford it I would be getting a new one made for peace of mind.
How can you be sure of getting a "good" used one? You would'nt find out if it is ok until it is fitted and you are using the car and it may then show up an ( usually intermittent) fault. I thought that you can get a new loom which can be wrapped etc to make it look like an original one. I have owned my 2wd Saff for nearly 25 years and about 5 years ago it started to have intermittent electrical faults and despite having it looked at several times the problem could not be found, had a brand new loom put in and the fault was gone! Your shout at the end of the day but for me it would be a brand new loom without a doubt.
timsrs
Nov 4, 2019 08:27 AM
