6 degree beam question
Old Jan 6, 2020 | 07:42 PM
3drRich's Avatar
3drRich
Default 6 degree beam question
Does anybody know how much adjustment you have on a 6degree rear beam to move the wheel forwards or backwards in the arch?
Old Jan 6, 2020 | 09:54 PM
Mark V8's Avatar
Mark V8
Without crawling around under my car with a steel rule I'm guessing a good 20mm, depends on how long the threads are on the spherical joint.
Old Jan 7, 2020 | 07:53 AM
Marc sierra's Avatar
Marc sierra
It also depends on the design of the 6 degree beam. Some still have the standard outer mount, so there is no adjustment at all (and also not needed).
Old Jan 7, 2020 | 12:54 PM
Caddyshack's Avatar
Caddyshack
If yours is the same as the pic then I would agree around 20mm, I did need that too as my shell was a tiny bit out where it had been adapted to the Cossie running gear (since been cut out and re done)
Old Jan 7, 2020 | 07:07 PM
3drRich's Avatar
3drRich
Thanks all. I have one of marks beams on my race car but getting under it is a bit of a mission at the minute so thought I’d ask the question.
reedy
Ford Escort RS Cosworth
Oct 23, 2008 05:06 PM
Staffi
112
Jul 15, 2008 11:30 AM
coachworz
Mar 19, 2008 11:02 PM
