Focus MK2 vibration over 70mph
Old Jan 5, 2020 | 12:40 PM
st220kyle's Avatar
st220kyle
Default Focus MK2 vibration over 70mph
Hi all,
focus 1.6 petrol mk2.5 gets a vibration through steering wheel and slightly on accelerator pedal when doing 70+mph
Tyes are only about a year old,
Any ideas people?
Old Jan 5, 2020 | 12:56 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Originally Posted by st220kyle
Hi all,
Any ideas people?
Just swap the front and rear wheels over, got to start somewhere.
Old Jan 5, 2020 | 09:18 PM
cossynut2's Avatar
cossynut2
10 Year Member
You may have lost some wheel balancing weights from one of the front wheels.
Old Jan 5, 2020 | 11:07 PM
scoooby slayer's Avatar
scoooby slayer
Swap front wheels to back, if steering vibration goes away it's a tyre or rim issue
Old Jan 7, 2020 | 07:40 PM
Could be a drive shaft??
Check for buckled wheels.
Old Jan 7, 2020 | 07:58 PM
st220kyle's Avatar
st220kyle
Cheers guys,
ill have a look on the weekend
How would you check if driveshafts have had it?
What am I looking for?
Old Jan 7, 2020 | 08:26 PM
nick46's Avatar
nick46
VR46 The G.O.A.T
I would start with checking the most obvious thing first and that is the wheel nuts. Then I'd make sure the tyre pressures are correct before having the wheels balanced. I had a similar issue a while ago when I had new front tyres. I noticed a very slight vibration at certain speeds. The tyre fitter couldn't of balanced the wheels correctly cos once it was done again it was fine.
But as others have said it could be any number of things from tyres that have worn oddly, buckled rims, drive shafts etc. I also had a drive shaft go on a Mk2 focus st and that was horrible. Felt like a bloody wheel was gonna fall off!
Old Jan 7, 2020 | 09:10 PM
cossynut2's Avatar
cossynut2
10 Year Member
Cheers guys,
Why not try the most usual reason first, if the front tyres are in good condition get the wheels balanced and see if that fixes it. It is a process of elimination and a wheel balance does'nt take long and is not costly
Old Jan 9, 2020 | 07:17 PM
st220kyle's Avatar
st220kyle
Your right, I'll check the obvious myself then get it booked in to get the wheels/tires checked and go from there
Old Jan 12, 2020 | 05:43 PM
st220kyle's Avatar
st220kyle
Checked it over today, drivers rear wheel has a flat spot on the actual rim itself. Ill either order another wheel or get that one repaired. I'll also get the rear tyres replaced while I'm at it and get the balancing checked on the fronts checked at the same time.
Old Jan 12, 2020 | 05:47 PM
st220kyle's Avatar
st220kyle
Just noticed if you scroll down, you'll see that in 2018 I had the exact same problem before, which was also the drivers side rear
FFS
Old Jan 12, 2020 | 08:59 PM
cossynut2's Avatar
cossynut2
10 Year Member
FFS
Probably a bloody big pothole you drove in!!! There are plenty of them!! At least you have found the problem and can now sort it out.
Old Jan 14, 2020 | 03:32 PM
Loomer's Avatar
Loomer
Common for shaft issues .
Old Jan 18, 2020 | 02:15 PM
st220kyle's Avatar
st220kyle
Problem now fixed
took the car to a wheel repair specialist this morning, they straightened out the damaged rear wheel and replaced the rear tires. I drove home with no vibrations!
I would of previously bet money the issue was caused by something at the front of the car but at least it was easily fixed.
Old Jan 18, 2020 | 08:45 PM
nick46's Avatar
nick46
VR46 The G.O.A.T
Problem now fixed
Excellent. Glad you got it sorted
Old Jan 18, 2020 | 09:24 PM
cossynut2's Avatar
cossynut2
10 Year Member
Problem now fixed
I thought it was more likely to be a front wheel problem but the main thing is you have got it sorted out and have vibration free driving again!!!
st220kyle
21
Dec 15, 2018 05:21 PM
coswurv
Ford Focus RS Parts for Sale.
Jun 6, 2012 05:48 PM
focus 4x4
Mar 17, 2011 10:36 PM
Paraic
Mar 2, 2010 03:30 PM
