Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
ST225 Oil filter housing leaking from wiring plug
Old Dec 16, 2019 | 08:02 PM
flo3flo's Avatar
flo3flo
Default ST225 Oil filter housing leaking from wiring plug
My ST225 2007 Oil filter housing (brand new genuine Volvo unit fitted 2 months ago) is leaking very slowly from the wiring connector plug.
Only a few drips per day but definitely leaking engine oil. The rest of the new housing unit appears to be dry. Its coming from inside the wiring connector, seeping down the square section of the housing and dripping off one corner.
Has anyone else ever had this? Am I unlucky enough to have bought a faulty unit or is there meant to be a rubber sealing ring on the wiring connector that pushes into the housing connector.
A drip of oil hanging off the corner
Oil pooling under the connector
Oil inside the connector socket
Old Jul 31, 2021 | 10:46 PM
Stylo's Avatar
Stylo
Hi
Did you find out what the problem was and how did you fix it.
Did you have any boost problems or just oil leak.
Mine also leaks and i think i have a vaccium leak because i have some boost problems. Engine stottering while flooring in 3 and 4 Gear.
Old Aug 1, 2021 | 12:52 PM
flo3flo's Avatar
flo3flo
Originally Posted by Stylo
Hi
Hi mate. Nope. Never solved the leak. We didn't notice any change in performance.
ajamesc
Aug 3, 2021 10:30 PM
BMG
Sep 20, 2018 07:01 PM
surrey_100e
Jan 3, 2012 05:41 PM
Disabled Account
Apr 12, 2005 11:39 PM
