Bigend Tightning Torque settings for Ford Focus 1.0 SCTi EcoBoost (2013)
Evening All
I'm rebuilding my 1.0l Ford Focus Ecoboost engine (engine code M2DA) focus ecoboost engine due to a broken piston skirt. I've rebored the bottom block, have new pistons rings, crank polished etc, just about put it all back together and realise I cannot access the crankshaft main bearing torque settings or conrod bolt torques settings as Ford do not release these as they want you to buy and entire cylinder block. I've checked Autodata in hope but they are not availabe. Would anyone know what they are please? Thank you. Apologies if I'm not posting in the right forum I wasn't sure if I should post here or in the Focus group.
Many thanks
Many thanks
maldivesred
Nov 20, 2019 08:35 PM
