Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
MK2 fiesta gear lever doesn't self center
Old Nov 14, 2019 | 09:45 PM
The Converted's Avatar
The Converted
Default MK2 fiesta gear lever doesn't self center
Hello, I'm new to the forum. I've bought a MK2 fiesta with a BC4 4 speed box. The gearstick doesn't self center any more which makes the shifting alot harder than you'd think.
Where are the springs that self center the lever? And are they serviceable. I can't find any information or parts online.
Thanks Andy
Old Nov 15, 2019 | 10:48 AM
GVK.'s Avatar
GVK.
I can't think on a mk2 it's been so long but some early Fiestas had a simple spring from the gear shifter under the car going to the chassis.
If not they will have springs inside the shifter tower at base of stick .
Old Nov 15, 2019 | 04:29 PM
The Converted
Thanks that's great, l'm just collecting the bits for a 1.8 black top swap so will need a decent shifter .
Old Nov 17, 2019 | 07:06 PM
The Converted
No springs in the box under the shifter.
The centering action must come from the gearbox . Gear selector on the gearbox has still got a tiny amount of return to it. I guess I'll have to rebuild the box
Old Jan 31, 2020 | 08:01 AM
XR2's Avatar
XR2
5-speed had the springs for lever centering in the plastic box underneath the car.
http://www.fordopedia.org/parts-cata...esta-mk1/H6.12 (Parts 14, 15, 17, 30 and 16, 18, 31)
4-speed had a spring on the selector rod
http://www.fordopedia.org/parts-cata...esta-mk1/H6.10 (Part No. 23)
http://www.fordopedia.org/parts-cata...esta-mk1/H6.12 (Part No. 6; probably only for cars built after 1986)
scuba-phil
Apr 16, 2018 01:48 PM
clarke5700
Nov 29, 2008 09:52 PM
