Beginning efforts to bring a 1990 Sierra RS Cos 4X4 to Group N Spec
Old Nov 11, 2019 | 03:50 PM
GT3Fed's Avatar
GT3Fed
Default Beginning efforts to bring a 1990 Sierra RS Cos 4X4 to Group N Spec
Hi All,
I've recently imported the aforementioned to the US, SoCal specifically. The car, a LHD model, appears to my current level of investigation rust-free with 41k kilometers and records show many details related to provenance. It has been a street car and has some investments in engine tuning that will documented when I have a chance to put in on 4WD dyno. Several questions for the group.
1. As Montune US is nearby and will undertake a rebuild to achieve varying outputs the issue is that the 200 block, as I understand it, can be brought to varying levels of tune. I would ask whether a bullet proof 400 bhp is possible? If so, I would appreciate recommendations regarding build bits.
2. Welding: The Group N specs allow a limited amount of welding. What structural changes beyond welding are recommended?
3. Wheels and tires: Currently, stock wheels are carrying 205/50/15 R rubber. What wheel type/tire would be recommend to comport with the Group N standard?
Would appreciate any other inputs and recommendations.
Howard
Old Nov 11, 2019 | 08:14 PM
smiley's Avatar
smiley
Sounds a good project will keep an eye on this I do have a facebook friend from the states with a wrc spec escort cosworth if you use fb pm your username I will put you in touch with him may be of help mate, bullet proof 400 bhp is easily possible on a 200 block stock engines can take that power my saph was running 380 on stock engine Siemens black 55lb injectors t35 turbo I had a 550 bhp spec mountune engine which I sold on as wasnt suitable for my project this had std crank cosworth racing pistons h beam rods with wrc squirt jets, a 200 block at the extreme can push over 700+ bhp
Old Nov 13, 2019 | 12:59 PM
GT3Fed's Avatar
GT3Fed
Thanks for your response and willingness to connect me with another US based Cosworth person. I'm not on FB but can be reached by email which I'll share with you directly if the forum allows.
Old Nov 24, 2019 | 03:26 PM
GT3Fed's Avatar
GT3Fed
Thanks for the reply- I can connect directly with your US contact by email as I'm not on FB. Thanks
SaphCos4x4_Dan
21
Mar 9, 2012 03:05 PM
turbostarkie
11
Mar 20, 2008 08:27 PM
Mark_w
Mar 11, 2008 03:41 PM
EsCosRacer
Jan 19, 2006 09:11 AM
xr4x4rs
12
Jan 8, 2006 09:09 PM
