Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
st225 boost help
Old Oct 11, 2019 | 08:01 PM
David J's Avatar
David J
Default st225 boost help
hi all
im new to the ford scene bought focus st225 but feels slow only boosts to a 1/4 on the gauge and don't think this is normal feels sluggish or is this normal or do I need boost solenoid as was common fault on my Vauxhalls or do I need upgrades cheers
Old Oct 11, 2019 | 10:58 PM
GVK.'s Avatar
GVK.
Start with a boost solenoid and check for leaks on intercooler/boost hoses
Old Oct 12, 2019 | 05:08 PM
thebigmacmoomin's Avatar
thebigmacmoomin
If the car is standard, it should only boost to about half way.
Old Oct 13, 2019 | 06:35 AM
STeve's Avatar
Super Moderator
only let downs with these cars is constant amounts of glitches from either boost or electrical related gremlins seams soon as you fix one another pops up grrrr
Old Oct 13, 2019 | 12:21 PM
thebigmacmoomin
Never had any issues at all with boost in over 9 years over 2 cars.
Old Oct 13, 2019 | 12:46 PM
STeve's Avatar
Super Moderator
you sir are lucky and fair play to you
Old Oct 13, 2019 | 01:21 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
When I got mine it had a little flutter/miss at low rpm as you built the boost up slowly. Full throttle it would put hard and boost off the gauge but mine has been re mapped. I gave mine a service and new plugs and boost solenoid and it sorted my issue
Philtingle
Jul 10, 2014 03:02 PM
saph-mad
Mar 5, 2012 12:12 PM
st2paul
Dec 12, 2011 03:11 PM
thebronze
Sep 14, 2008 12:15 PM
Alps Pacino
Dec 7, 2004 10:23 PM
