Camshaft tight to turn
Old Oct 10, 2019 | 08:46 PM
timsrs's Avatar
timsrs
Default Camshaft tight to turn
I’m putting my engine back together from putting new piston rings on and just doing head work ( new seals etc )
my inlet is a BD14 and when the Cam caps are only finger tight the cam is hard to turn compared to the standard exhaust
move not got and tappets in st moment so should be free with no resistance
mot will turn but not easy and this doesn’t feel right
Old Oct 11, 2019 | 04:49 PM
Caddyshack's Avatar
Caddyshack
So there is no pressure applied from the valve train?
Old Oct 11, 2019 | 11:01 PM
GVK.'s Avatar
GVK.
Have you got the caps on the right way round?
Old Oct 12, 2019 | 08:55 AM
Adam-M's Avatar
Adam-M
Try putting your exhaust cam in the inlet side to see if it’s any better, maybe your head has a cap or two fitted from another head due to damage and this is just you realising.
Old Oct 13, 2019 | 06:43 PM
timsrs's Avatar
timsrs
Hi all
yes caps on right
no hydraulic lifters in so no drag
swapped cams and problem moves so confirmation a fault with the cam
head and cam are at an engineering shop now so I’ll let you know what they find
cheers
Old Oct 13, 2019 | 08:02 PM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
its not clear from your post if the BD14 cam is new or used.
However, if the head has been overheated at some point it might have warped and when that happens the cam journals wear down (not the ally caps for some reason).
it may be that an old (worn) cam still turns fine in the head but a new one which is the correct and slightly bigger diameter won't.
the cams have a machined circle on them which is not used by the engine but is a reference to the 4 journal diameters when the cam is new.
measure this with a vernier/micrometer then measure the journals to check that they are not worn on one of the cams, this might give you some idea of what the problem is.
another check for a warped head (or one that was once warped and caused cam wear but the warp was apparently fixed by facing off the head afterwards) is to lie a dead straight edge across the lower bearings and see if it rocks (when they warp the middle 2 rise up slightly)
COLEYST200
17
May 30, 2013 11:56 AM
Rockhound
Mar 13, 2011 07:12 PM
jonesymk2
13
Jun 11, 2010 09:16 PM
mark_24v_wiring
Jan 21, 2008 09:19 PM
abdr500
Aug 13, 2006 02:10 PM
