Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Mk2 1.8 tdci duraturq engine
Old Oct 10, 2019 | 06:35 PM
Jez Melsopp's Avatar
Jez Melsopp
Default Mk2 1.8 tdci duraturq engine
Hi I’ve removed EGR cover only to find one of the tiny roller pins with very small circlip in side the alloy casing it’s come off the Brass EGR valve and the other side one has come off as well with the circlip attached these seem to connect to the centre pin of the Brass EGR valve my question is can these be put back in has anyone done this or know of this I took it off as I had fault code p0490 or is it now a case of replacing the whole inlet manifold from a scrapyard any help would be greatly appreciated
cheers Jez
Sussex1970
Ford Focus Diesel
Mar 31, 2017 01:03 PM
focus111
Ford Focus RS
25
Jan 27, 2017 07:20 PM
pauloopnorth
Aug 19, 2014 06:58 PM
DrewHughes
Oct 4, 2010 02:46 PM
