Sapphire Cosworth fuses.
Old Oct 5, 2019 | 09:28 PM
Old Geezer's Avatar
Old Geezer
Default Sapphire Cosworth fuses.
Hi All.
4x4 Sapphire Cosworth...Is there a mystery fuse box under the dash somewhere which might hold the key to why my ABS doesn't seem to want to work any more? If there is, I can't find it from the handbook or manual..
Cheers.
Old Oct 9, 2019 | 08:04 PM
2wd's Avatar
2wd
Originally Posted by Old Geezer
Hi All.
Cheers.
No fuse box ...but there is some relays with fuses under the dash in the pass. side...cant remember all..but the yellow one is fuel pump relay..there is a green and maybe a purple one too as far as I remember.
Old Oct 10, 2019 | 12:47 PM
martysmartie's Avatar
martysmartie
As above, however when you say does not work, do you mean the pump or the ABS itself?
Martin
indycos
223
Mar 28, 2021 09:56 PM
RC4
Nov 16, 2011 05:51 PM
mint_s2
Nov 27, 2005 08:49 PM
All4it
16
Aug 22, 2005 11:52 AM
