Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk6 Fiesta ST Pro's & Con's
Old Sep 26, 2019 | 03:09 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Default Mk6 Fiesta ST Pro's & Con's
As some of you may remember I used to own a really tidy ST170 (for some 5 years), but I sold it and moved on to a Toyota Carina E, which is a 3 year project, well that was the plan, but if any of you have followed my build videos, it's taking a rather long time to find bits, or have bits made.
So the plan is to get a second car, yep, silly, but I'm split between a Clio 182 - Clio 197, or a Fiesta ST150 (mk6) which is my preferred choice as I work at a Ford dealership. I just wondered if anyone had any first hand experience of using one as a daily, things like, where do they rot, common issues etc. We obviously have the cars come into where I work for servicing and some repairs, but nothing beats hearing straight from an owner.
Thanks in advance.
Old Sep 26, 2019 | 03:16 PM
STeve's Avatar
Super Moderator
as much as I am a ford enthusiast to the core st150s are pretty weak and feel you would be far better off with clio
Old Sep 26, 2019 | 07:11 PM
massivewangers's Avatar
massivewangers
The above is right to be honest. I drove a Fiesta ST when they first came out and they do feel rather flat in my opinion. I'm sure that they come alive with some mods but, in standard trim, they leave a bit to be desired in my view.
I run a Clio 197 as a daily and have had a 172 Cup in the past. For a daily, I would 100% take a 197/200 over a 172/182. The 1*2 does feel a bit more raw, but the more modern cars are a bit nicer to live with by virtue of being a bit bigger and more grown-up. That's not to say that they don't have their flaws - the gearing is short so the fuel economy isn't world beating and the front suspension requires careful maintenance - but they are a good steer overall. Try and buy one with timing belt done recently as it avoids a bit of initial cost (c.£500) but the life is ok (60k/5years) and better if you can find one that's had the front swivel joints replaced - they use a similar front suspension arrangement to a MK2 Focus RS with twin pivot hubs. They are pretty tough overall though. With fresh suspension and decent rubber, they are an extremely capable car. If you can find one with the optional Recaro seats, it's worth going for and, if you are willing to spend a bit more, a 200 Cup (or a regular one with the Cup chassis option) is the one to have; it has the best spring/damper/roll bar combo and a slightly quicker steering rack. Autocar did a video when they came out and a MK2 Focus RS couldn't get away with it on a twisty track.
The 197/200 is a bit more expensive to buy than a Fiesta ST, but worth it in my view. The Fiesta is marginally nicer inside, but the Clio is the more capable car in my view, and looks better with the wider arches etc.
MJK 24
Jan 8, 2026 05:30 PM
jitsu579
Sep 8, 2017 05:24 PM
jitsu579
Sep 8, 2017 05:00 PM
James Mac
Apr 20, 2017 10:43 AM
