Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
short ratio ford focus 1.6
Old Aug 24, 2019 | 04:43 PM
focus1.6's Avatar
focus1.6
Talking short ratio ford focus 1.6
Hi everyone.
I had the bad idea of preparing a 1.6 mk1 focus for use on the track.
after many mishaps, they are at the end of the project.
I still have the gearbox problem.
I replaced the change first with that of the fiesta 1.4 mk4, discovering that it had the same ratio, then with that of the fiesta 1.25 mk4 which is actually a little shorter, but not as I would like.
I was looking for a sprocket-crown unit in ford with a higher ratio so that I could still gain something in gear changes. I currently lose almost 1,500 laps.
does anyone know what kind of final report carries the fiesta mk4 1.25 gearbox?
or where can I find one a little shorter?
I had thought of the fiesta mk3 1.1 or the 1.3 kat. the 1.4 was already too powerful
I can find a standard ford one? make it build would cost too much and not the guarantees of duration as the original pieces t
hanks
pieterjan
Jan 9, 2013 06:23 AM
Luke_si
Aug 1, 2005 02:29 PM
abdr500
May 13, 2005 11:08 PM
2001ode
Aug 18, 2004 04:45 PM
