Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Under boost problem st 225 help needed
Old Aug 4, 2019 | 02:37 PM
Francismcginn27's Avatar
Francismcginn27
F420
Default Under boost problem st 225 help needed
So changed my boost control solenoid yesterday to a Mac 3 port as it was bringing on eml and an under boost fault code on my snap on reader . When I changed to the 3 port sensor the eml went out but it still brings up an underboost code the code will delete and stay off for a while but it will come back on if I done a few hard runs up the road in it . I’m wondering do you need a map to suit the 3 port boost solenoid .
Old Aug 4, 2019 | 03:43 PM
STeve's Avatar
Super Moderator
more than likely as these cars are so sensitive when it comes to that sort of thing
Old Aug 6, 2019 | 10:05 PM
Jay,'s Avatar
Jay,
Sponsor
Use a oem boost solenoid the mac one needs a remap iirc and you not going to gain anything from it
andrewg
14
Jan 21, 2009 06:01 PM
Ginge !
Jan 18, 2009 01:45 PM
EssexMikeSi
May 27, 2008 07:22 PM
tansey
May 13, 2005 11:06 AM
