Fuel pump (model/part number)
Old Jul 24, 2019 | 09:58 AM
qed296's Avatar
qed296
Default Fuel pump (model/part number)
Morning all,
Just looking to do the fuel pump loom re wire on my J reg 4x4 sapphire.
As far as im aware its the original pump.
My question is....what is the original pump called/make/model.
All the looms ive found available state "044 upgrade loom" or "uprated pump 044 loom kit".
Thanks in advance.
Old Jul 24, 2019 | 10:49 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
I think the issue is the original style connectors are no longer available and i guess most people would upgrade the pump at the same time anyway.
Whats your voltage at the pump? I know its more money but put an 044 in or DW350 and be done with it.
Old Jul 24, 2019 | 10:50 AM
qed296's Avatar
qed296
Thanks for the reply, so the 044 is an upgraded pump from original fit.
044 ring terminal
O/e push fit terminal
Old Jul 24, 2019 | 10:52 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
Its bosch 0580254941
Old Jul 24, 2019 | 12:48 PM
qed296's Avatar
qed296
This will be the one then to use on my o/e pump
Old Jul 24, 2019 | 04:28 PM
cossynut2's Avatar
cossynut2
10 Year Member
That should do the job as you are still using the O/E fuel pump.Some others have said fit a new 044 uprated pump but it is not needed unless you are going for a big power increase.
Old Jul 25, 2019 | 01:36 PM
4x4kiwi's Avatar
4x4kiwi
Probably should have started a new thread but am I correct in thinking the original pump can be replaced with a 044 without causing any problems. I am guessing it just causes more fuel to be returned to the tank than before with one fitted.
Thanks David
Old Jul 25, 2019 | 03:52 PM
tosh's Avatar
tosh
Thanks David
Im no expert but I thought it was the fuel regulator that governs the flow and pressure of the fuel system! But will probably be corrected on that by someone who is more mechanically minded with me.
Old Jul 25, 2019 | 05:02 PM
qed296's Avatar
qed296
I understood it that the o44 had a higher pump rate....getting more fuel to business end quicker so to avoid lean running on bigger bhp engines..
Old Jul 25, 2019 | 07:11 PM
I got told to fit a 0044 pump cause they supply more fuel. The difference between the electrical connections on the 2 pumps are. The 0044 pump uses ring terminals and 2 nuts to attach the wiring connections to the pump. A standard cossie pump has 2 push in connectors.
Old Jul 25, 2019 | 09:16 PM
cossynut2's Avatar
cossynut2
10 Year Member
You are correct,my Saff has 890cc Siemens injectors and a T38 turbo so needs an uprated 044 fuel pump but with a standard power engine it is not needed.
Old Jul 27, 2019 | 03:05 PM
qed296's Avatar
qed296
Looms arrived. Looks to be good quality....has a bag of different connections, tie wraps and destructions.
Ł45 posted.Ill have ago at fitting in the next week......anybody interested in pics as i go along the installation??
Old Jul 27, 2019 | 09:19 PM
cossynut2's Avatar
cossynut2
10 Year Member
It looks like a good kit for the money. Should be a big improvement on the original Ford wiring.
Old Jul 28, 2019 | 06:39 AM
bigdel's Avatar
bigdel
I replaced the loom with one similar to yours due to low voltage at the pump, decided to replace my original pump with an 044 whilst it was up in the air just as a 'belt and braces' fix.
I've had no problems whatsoever since doing it, fuel pressure at the rail is exactly where it needs to be and holds it whilst under boost, which the old set up wasn't doing.
Old Jul 29, 2019 | 06:27 PM
qed296's Avatar
qed296
Clean forgot to take progress pics. Its in now down to the boot, just need to connect up to the pump.
I'm ordering the fan loom now, that can sit next to the fan relay.
MichaelG
Jan 4, 2006 08:58 PM
cossiescott
Sep 12, 2005 07:44 PM
R4N SS
Jun 24, 2005 01:19 PM
the strut brace
Mar 26, 2005 05:12 PM
