Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Focus mk2 srs module location
Old Jul 3, 2019 | 01:48 PM
Ellwood's Avatar
Ellwood
Default Focus mk2 srs module location
Hi
Not sure if I should be in the muppet room! I'm looking for a location to the restraint control module on my 58 reg 1.8 tdci estate. I have the airbag light on and I'd like to try changing the module. Codes are B1994, B1877 and B1318.
Thanks in advance
Old Jul 3, 2019 | 04:08 PM
STeve's Avatar
Super Moderator
normally under centre console near hand brake
Old Jul 3, 2019 | 04:46 PM
focusv8's Avatar
focusv8
Have you checked the relevant connectors?
If you Google the Codes there are plenty of references to bad connections
I believe the replacement module may need programming to the car.
OldDan
Mar 5, 2009 08:47 PM
Jim Galbally
81
Dec 21, 2004 03:27 PM
