Check out this new Wideband lambda device.
Looks well cool and you can plug in EGT sensor to it as well + log a bunch of values like ACT, MAP, TPS, DutyCycle, RPM etc.
Just check all the options you got.
More info here:
http://www.plxdevices.com/R-500_productinfo.htm
/Andreas
More info here:
/Andreas
Looks cool, I wish these sort of things would be easily dash mountable though, a bit like a gauge, so it isn't stuck to the dash with tape, velcro etc. You have to be a Damo wiz to fab something up.
Ive looked into this a bit more now and unfortuneately while logging the EGT and AFR will occupy 2 of the avaialbe channels. This means you only got 2 more channels to log analog signals like MAP, ACT, TPS.
Would have been so nice if it had some more channels so you could log all essential values.
Techedge logging is much better, although there isn't any good software available with it. the manufacturer does provide you with the data stream details so that you can write your own (i have made a virtual dashboard using VBA).
