Ford Scorpio 24v Cosworth Starting problems
Old Jun 27, 2019 | 06:31 PM
nbs's Avatar
nbs
Default Ford Scorpio 24v Cosworth Starting problems
I have a 24v Cosworth (bob engine factory fitted) in my 1995 Scorpio Cardinal hearse. Before I bought it it was parked up for almost a year. The garage told the previous owner the fuel pump had packed up. I found it was the fuel cut off switch had tripped not the pump. Now it starts and runs fine until you switch off and leave for 5 minutes or more. Disconnect and reconnect the battery and it starts fine again until left for 5 minutes or more. Its as if something is being reset when the battery is disconnected / reconnected. Any suggestions as to whats happening ?
Old Jul 7, 2019 | 04:25 PM
robrs2's Avatar
robrs2
You will find the engine loom in the V of the engine is probably crispy. The heat off the engine breaks down the insulation and the wires can short out.
mr_scorpio
39
Feb 19, 2013 08:21 PM
MERKUR XR4ti
Nov 21, 2012 11:39 AM
TurboFlush
Jul 21, 2007 11:16 PM
BigChuck
Apr 24, 2007 03:46 PM
