Rear Wishbone Washers
Old Jun 23, 2019 | 09:21 AM
adduk's Avatar
adduk
Default Rear Wishbone Washers
All
Can anyone help with which washers need to go where on the rear setup for the wishbone.
I assume there should be washers on the long bolts that run through the hub and wishbone either side of the bushes. Anyone have any pictures showing which ones they should be? Same goes for where the wishbone fits to the shell, i have removed the rear compensator setup so should there just be a nut and bolt.
Last thing, with the new washers that come with the pollybushes, should the curve of the washer be outward or inward to the bush. I have seen them fitted both ways but i am sue they should be outward.
Trying to get the rear built up today but not sure on the above.
Old Aug 18, 2019 | 08:15 PM
Si74's Avatar
Si74
As to last bit, defo washers outwards. As to the other bits will see if I can find photos of my resto. Thru the chassis, washers both sides I think, hubs, not sure any are required if you use nylock nuts.
Marc sierra
Apr 11, 2016 10:45 AM
tonytantrum
Aug 7, 2010 03:10 PM
Sp3no
Mar 30, 2010 03:19 PM
northerner
23
Feb 11, 2008 11:56 AM
gibbo frst
11
Jul 22, 2007 01:13 PM
