Question about Focus ST170 transmission.
Old May 14, 2019 | 10:21 AM
Tommelom93's Avatar
Tommelom93
Default Question about Focus ST170 transmission.
Hi.
I am wondering if an transmission from a Focus ST170 fits on my Mondeo mk1 2.0L zetec silvertop?
Kindly regards Tom
Old May 14, 2019 | 03:40 PM
big_wasa's Avatar
big_wasa
Yep bolt on fit. Clutch is another matter.
Old May 14, 2019 | 05:45 PM
Tommelom93's Avatar
Tommelom93
Ok. Do you know which clutch I can use?
Old May 14, 2019 | 06:46 PM
big_wasa's Avatar
big_wasa
St170 has a dual mass flywheel and a unique clutch and cover plate. They started out with 230mm but half way through it’s life they increased it to 240mm.
It has an odd first motion shaft pattern.
Best no expense spared option is somthing like a Ttv single mass flywheel and a Helix clutch. There are other makes.
Not a lot has been done diy so the box is almost worthless over here.
The standard Zetec flywheel comes in 220mm and 240mm but is not as deep as the St.
The unsprung 240mm st plate should fit the Zetec flywheel and cover plate but the csc won’t reach properly and can’t be spaced easily as the back has the gearbox oil seal built in. The next issue is there probably isn’t enough first motion shaft left either. And the unsprung plate would be very harsh on the road.
There is a plate from a 90’s Vauxhall Calibra turbo that’s a match and has the sprung Cush drive but it’s an odd one to track down.
Old May 14, 2019 | 07:12 PM
Tommelom93's Avatar
Tommelom93
Ok. Thank you for the information and quick answer Guess I have to think this through and go from there.
Kindly regards Tom
babscossie
Sep 29, 2008 07:07 PM
Spiky
Apr 3, 2008 01:13 PM
4x4
Apr 3, 2007 08:29 AM
xr-stu
Mar 31, 2006 12:46 AM
JAP CRAP
32
Mar 3, 2005 05:24 PM
