Focus RS mk1 Misfire on Hight Boost
Old May 3, 2019 | 10:55 AM
kevin1987's Avatar
kevin1987
Default Focus RS mk1 Misfire on Hight Boost
Hello guy's. I have misfire on high boost. as soon as I disconnect the boost controll valve and have only 1.0bar boost pressure, the misfire are gone. Spark gapped to 0.7mm, new leads to coil did not solve the problem.
Car is Running Sabre stg.2
380S Turbo
630 Deka Siemens injectors
Fuel pumpe
200cell cat
What can produce the misfire?
Old May 4, 2019 | 04:32 PM
bigdel's Avatar
bigdel
What plugs are you running?
Old May 6, 2019 | 05:46 AM
kevin1987's Avatar
kevin1987
Hello, sorry my mistake I have not yet set the new spark plugs to 0.7mm. So far he's been doing well for 130km. I'll contact you if there are problems again
K500BHP
Jul 22, 2006 04:36 PM
zvhturbo
Nov 3, 2005 06:12 PM
rstjoe
Jun 11, 2005 05:54 PM
tregmatt
Jun 8, 2005 07:35 AM
john_p_b
Jan 25, 2005 08:29 AM
