2011 Fiesta blower motor
Old Mar 31, 2019 | 11:59 PM
Paulsfiesta's Avatar
Paulsfiesta
Default 2011 Fiesta blower motor
Hi all
Got Fiesta 1.4 TDCi Style+ 2011 and the heater has stopped working.
It was working intermittently so I replaced the capacitor and it's stopped working completely.
Went into garage for coil spring and they said its the blower motor as its getting power but they won't do it as they said it's a pain in the.... to do.
Before I try and find someone else just wanted to double check if there's anything else it could be?
Was driving yesterday and hit a bump in the road and they came on, then when I tried to change the speed they went off again. Does that sound like the blower motor?
Fault was that the heaters would work intermittently, usually when the car started and would stop after a bit. It didn't matter what seeing they were on, I know with capacitor fault they'd often only work on 4 but changed it in case, then they stopped working at all!
Also the drivers side of the heated window doesn't work but I don't suppose that's linked.
Thanks for reading 👍
Piston Broke
Nov 9, 2014 05:27 PM
Johnny Knoxville
Oct 28, 2009 06:03 PM
Paul Cos
Ford Escort RS Cosworth
Sep 7, 2008 08:18 PM
captiva
13
Jan 15, 2007 06:58 AM
