Where to get multirib supercharger belt
Where can i get some good qaulity multirib super chargerbelts for my sprintex xr4i. Belt should be around 1219mm 10rib or 48inches. It's pretty hard to find here in the netherlands
Anywhere that sells belts. If motor factors cant, industrial power transmission etc. ( assuming PK section of belt which is typical size on automotive stuff )
10PK1219
Gates, Fenner, Optibelt are common brands.
Eriks in the UK do Fenner...no doubt there are suppliers all over Europe
https://www.fptgroup.com/Ribbed-Belts/
Hayley Bearings in the UK do Gates and possibly others.
Optibelt list 1200 and 1222mm belts. Damned if I can remember their main supplier
Most of the above should be able to source any width, as often they're just cut from a sleeve to whatever width the customer needs.
cheap unbranded listing.
https://www.ebay.co.uk/itm/10PK1200-...YAAOSwE8daYJTq
5PK1220 seems common......jury's out on running a pair side by side. You may get away with it, you may not.
10PK1219
https://www.ebay.co.uk/itm/Multi-V-Drive-Belt-10PK1215ES-Gates-5000681376-10PK1215-10PK1210-Quality-New/232415014398?epid=1042092494&hash=item361d03adfe:g :Fh0AAOSwSc1bvnBp
https://www.ebay.co.uk/itm/10PK1213-CONTITECH-DRIVE-BELT-MICRO-V-MULTI-RIBBED-BELT-I-NEW-OE-REPLACEMENT/263714508743?epid=1250289934&hash=item3d669c0fc7:g :j2YAAOSwkFZb2aL1
Germany
https://www.ebay.co.uk/itm/CONTITECH...cAAOSw-yJcHAWR
Poland
https://www.ebay.co.uk/itm/KEILRIPPE...0AAOSwOIxclCAf
Germany
Poland
wskxd14
May 23, 2008 07:51 AM
Stavros
Oct 16, 2006 04:07 PM
