fiesta-puma conversion fuel line help
Old Jan 22, 2019 | 06:48 PM
st220kyle's Avatar
st220kyle
Default fiesta-puma conversion fuel line help
When doing the puma conversion what are people doing with the fuel lines? As its a bit of a different setup from one to the other.
fiesta has fuel lines into each end of the rail but i think puma has both lines into one end of the rail.
Pictures and advice would be great
Old Jan 22, 2019 | 07:32 PM
big_wasa's Avatar
big_wasa
I havnt seen a Puma but the,
St170 runs a very complicated returnless fuel pump. It’s monitored by the ecu and the pump is modulated via a driver modual.
The St220 also runs a returnless fuel system but it’s much simpler. The pump has the regulator built into the return side of the pump.
so fuel out the pump, through a second filter and upto the rail. Excess pressure is bled of from just after the filter and back to the regulator in the pump.
I’ve seen a few cars running this setup.
Old Jan 22, 2019 | 07:38 PM
big_wasa's Avatar
big_wasa
london_chris
Ford Puma
Jul 18, 2019 06:44 PM
bigdel
Aug 1, 2016 11:02 AM
AlexD
Ford Escort RS Cosworth
Oct 14, 2008 09:02 PM
gordyshreds
Sep 24, 2006 05:11 AM
