92 ford escort cosworth stub axles
Old Jan 21, 2019 | 04:06 PM
oibren85's Avatar
oibren85
If in Doubt Flat Out...
Default 92 ford escort cosworth stub axles
Hi,
I'm trying to find replacement stub axles for my escos (big turbo). Seem to be a nightmare trying to find a new set. Anyone can point me in the right direction for new or a good used set?
Thanks
Brendan.
Old Jan 21, 2019 | 04:35 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
the inner ones that go in the diff or the outer ones that go in the hub?
Old Jan 21, 2019 | 04:41 PM
oibren85's Avatar
oibren85
looking for the outer ones going into the hub
Old Jan 21, 2019 | 07:00 PM
Caddyshack's Avatar
Caddyshack
I bought mine from Mark at MK, I then went for sleeved ones for Wrc hubs and had them lightened.
Old Jan 21, 2019 | 07:02 PM
Caddyshack's Avatar
Caddyshack
Old Jan 21, 2019 | 09:00 PM
Turbo Zetec
Engine Machinist
what's wrong with the original ones? think i may have a pair or two in my shed.
also, they should be the same as any non cosworth 2wd sierra?
Old Jan 21, 2019 | 09:03 PM
oibren85's Avatar
oibren85
Have a look on anembo. http://anembo-engineering.mybigcomme...eatured&page=1
Thanks will have a look.
Previous owner didnt realise the bearings had gone and they are mullard. they would need re-sleeving or new ones and Ford dont have any. Let me know and happy to buy them if you let me know a price.
Thanks guys
Old Jan 21, 2019 | 11:08 PM
Turbo Zetec
Engine Machinist
try searching for drive flanges instead, you may find what you're after a stub axle to me is the splined part bolted onto the cv joint but people seem to interchange both names with both parts.
here's someone reasonably local that will have some for sure:
https://www.facebook.com/ascardismantlers/
found these on ebay too:
https://www.ebay.co.uk/itm/huFord-Si...2BU:rk:33:pf:0
Old Jan 22, 2019 | 07:36 AM
Marc sierra's Avatar
Marc sierra
what are you actually looking for, front or rears?
Old Jan 22, 2019 | 07:40 AM
stevenebm's Avatar
stevenebm
post whore
Is it just the stub axle you need like below or the hub carrier where the bearing is,this stuff isn't hard to find as any breaker will have them or eBay,
https://rover.ebay.com/rover/0/0/0?m...2F254033892426
Old Jan 22, 2019 | 03:37 PM
oibren85's Avatar
oibren85
Thanks guys, it's from my mechanic that's looking for them as he's removed mine and they look shit. This is the picture he sent me. So it's these that I need. He called them stub axles.
Old Jan 22, 2019 | 04:41 PM
THE RADMAN's Avatar
THE RADMAN
have you actually measured them or tried a bearing on them to see how worn they are?
Old Jan 22, 2019 | 07:11 PM
oibren85's Avatar
oibren85
I haven't, personally I haven't seen them, the guy fitting new suspension and doing the mechanical side of it has said that they aren't in great condition and the bearings aren't great and need to be sleeved to make it work. Is not a chancer or a poor mechanic so fully trust his word on it so just looking for some decent ones before we get them sleeved and pay that cost!
jessie_rs
Mar 24, 2015 01:55 PM
airzfocus
Ford Focus RS
Apr 13, 2010 05:59 PM
Gavan Hood
22
Jul 7, 2006 08:18 PM
