Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Oil in clutch housing
Old Jan 16, 2019 | 09:15 AM
MarkHulme's Avatar
MarkHulme
Default Oil in clutch housing
Hi Guys ,
Upon removing the gearbox on my 2004 Ford Focus Petrol 1.8 in order to replace the clutch , I noticed a quantity of oil drip out of the bottom engine / gearbox joint.
Upon inspection , there was no trace of oil on the clutch , flywheel or the crankshaft seal , yet the side of the engine was wet with oil , not only on the area enclosed by the gearbox , but also right up the whole side of the engine , meaning I have an oil leak somewhere above the gearbox which is running down onto the engine / gearbox joint .
My question is , could this external oil leak have found its way past the joint and into the clutch housing ?
Secondly , Haynes state that part of the seal renewal proceeded involves removing the sump.
I don't doubt that it's necessary , but I was wondering why ?
Many thanks.
dlf3yburt
Jul 25, 2013 09:53 PM
Joe91
Sep 5, 2012 03:46 PM
saph cos rob
Mar 10, 2012 08:13 PM
wimwerf
Mar 30, 2006 01:23 PM
SapphyMike
Apr 11, 2005 09:54 AM
