Position the battery in wheel well
Old Jan 8, 2019 | 06:05 PM
krolly's Avatar
krolly
Default Position the battery in wheel well
Hi guys could anyone inform me the best route to move the battery to the spare wheel well and also if any one could inform me the cable length and ideal size be great
Old Jan 10, 2019 | 03:17 PM
bassboy's Avatar
bassboy
I have done tons of battery relocation and additional battery kits...what you will need is
x amount of positive power cable (2 or 0g OFC cable should be used)
x amount of earth cable (same gauge as above), this will be used to earth the battery in the rear of the vehicle to the chassis. You can also run another length of cable from the battery to the front of the vehicle...all the connections that are usually earthed at the battery, you can connect them to a distribution block - this block can be earthed direct to chassis or ran back to the battery...this is what will dictate the earth lead length
1 or 2 distribution blocks so you can connect everything together and run the thick positive cable to the battery. Either 1 just for the positive, or add a second for the earth too
2 fuse holders - fuse the positive cable in the engine bay, and one near the battery
Crimp connectors
Battery tray or make your own
On average, most cars will use 4-5m of positive and around 1m of negative
Make sure you use PROPER OFC cable, CCA cable will just deteriorate in the engine bay when exposed to moisture/water etc
Any extra extra needed just give me a shout
Old Jan 12, 2019 | 01:42 PM
krolly's Avatar
krolly
Cheers mate I have most of the bits but what kind of fuse holder and size would you use on the live under the bonnet ?
Old Jan 22, 2019 | 10:29 AM
bassboy's Avatar
bassboy
What size is the cable
Tank Mike
Oct 28, 2006 12:02 PM
Snowy_Astra
50
Feb 8, 2006 10:27 PM
