new crown and pinion for sierra still available?
Anyone who knows where to get a new 3.14 or 3.36 crown and pinion set for a 7 inch diff?
Im busy with an supercharged v6 but wan´t some longer ratio´s on the mt75 as ithink the rpm on the freeway etc will become too high.
For a 7" diff the ratio would be 3.38, not 3.36. The 3.36 is for a 7.5" diff. But why not look for one of those? The 3.36 was fitted to Scorpio diesels and the 7.5" will be stronger than the 7" as well. I think 3.14 might actually be too long.
You would need a different beam (from a Scorpio mk1 or Sierra) for the 7.5" diff as the top mount of the 7.5" diff is wider. But if you were planning on fitting a 6 degree beam anyway it would be best to get a 6 degree beam based on the 7.5" diff. I have one on the Cosworth aswell, even though I still have the 7" diff on that. I put a spacer in between to fill the gap. But at least I can upgrade to a 7.5" diff whenever I want to.
IIRC I think I read that changing to the diesel 5th gear reduces the RPM at 100kph by roughly 500RPM.
I don´t know where to get a decent priced 7´5 inch diff. I have a good 7 inch and i guess 300hp isn´t overkill for a 7inch. The car won´t like high revs so i need a better diff ratio.
The T9 had a much better ratio than the mt75. If i mount a 3.38 or 3.36 diff the ratio would be alot better and closer to the t9.
I disagree that a 3.14 would be to heavy. In first gear compared to a 3.62 t9 it is only 3 km/h diffrence. The second and third gear are lower than the t9 and 4 and 5th a bit larger. Also the the torque at the diff would be alot less if im right!
and with a 3.14 diff the car would 130km/h at 3000rpm instead of the 3650 with the 3.62 it has now.
@Stroker Yes i could do that but then i need a whole gearbox because the secundary shaft would also have a diffrent number of teeth. So i need 2 gearboxes just to get the 5th gear heavier. The best option would be to swap for a MAZDA RX8 6 speed box to get the best gearing.
@Caddyshack @jay thanks for the links!!!
M K
Dec 17, 2011 01:08 PM
MERKUR XR4ti
Jan 13, 2010 08:23 AM
