Cosworth 2WD brake compensating valve
Old Jan 2, 2019 | 02:12 PM
timsrs's Avatar
timsrs
Default Cosworth 2WD brake compensating valve
Hi
im running new brake pipes on my car and got the valve out
im not sure if it’s working right
i can blow down both ends but the outlet seems less pressure ( not sure if this is right )
should they be mounted at a certain angle to work
mot wasn’t leaking when I removed
TIA
Old Jan 18, 2019 | 07:20 PM
sparky74's Avatar
sparky74
Default Brake valve
I found out de hard way mine wasn’t working . When abs is working fine you’ll never know whether it’s working or not . However if abs light comes on for faulty abs sensor for example abs won’t work . If you now brake hard back of car will come around .one way to test it is unplug one of de abs sensors and brake hard at about 10 mph and see if back of car comes around a bit
Old Jan 18, 2019 | 07:44 PM
timsrs's Avatar
timsrs
Thanks for the info
when resto is complete I’ll test as you’ve said
cheers.
Wull79
Oct 20, 2007 06:58 AM
Wull79
Oct 18, 2007 10:08 PM
182sam
May 19, 2006 07:42 AM
StephenC
Jul 28, 2004 08:56 AM
