Sapphire fuel filler hose
Old Dec 31, 2018 | 03:08 PM
Adam-M's Avatar
Adam-M
Default Sapphire fuel filler hose
Does anyone know where I can get a new hose or a good alternative replacement for the one I’ve circled in red? Mine has went rock hard and split and I suspect most originals would be the same. Maybe the material isn’t fuel resistant.....
Old Jan 1, 2019 | 06:01 PM
Adam-M's Avatar
Adam-M
Anyone help?
Contacted Graham Goode to ask about their aftermarket fuel tanks to see if they know of any surge issues
Old Jan 1, 2019 | 06:19 PM
cossie330's Avatar
cossie330
I used some flouro lined silicone hose on mine
Old Jan 1, 2019 | 06:29 PM
Adam-M's Avatar
Adam-M
thanks for the reply, how did you get round the size difference between the filler neck and the tank? I measured my tank fitting at 13mm OD and filler neck 20mm OD
Old Jan 1, 2019 | 06:35 PM
cossie330's Avatar
cossie330
From memory I had it custom made, was quite a few years ago so forgot about the size difference
BMG
Sep 20, 2018 07:01 PM
graham jamieson
Aug 6, 2010 07:24 PM
notroubleclubber
Feb 10, 2009 07:15 PM
redrsmk5
Ford Escort RS Cosworth
Mar 11, 2007 10:55 PM
