Sierra 2.5 T
Old Dec 16, 2018 | 12:54 PM
Danijel4x4's Avatar
Danijel4x4
Default Sierra 2.5 T
Hi, i'm new here and i would like to show little something that we can/have made in Zagreb, Croatia
It started when my dad bought 1.6 CLX in far away 1991. and it was a great car....somewhere about 2003. evil me happened to her (sierra) and it all started
Long story short...first project was to put in 2.0 DOHC and 4x4 transmission and that was great.....for a while
Idea was born when a friend bought Scorpio 2.3 '98. for parts and asked me if i want to buy engine...that was when it really started
Here are some pics and youtube's that i have found
This one is from internet, i could not find pics on PC :/
Old Dec 23, 2018 | 06:47 AM
Danijel4x4's Avatar
Danijel4x4
Few more pics i have found...
Old Dec 24, 2018 | 08:36 AM
Cook matey. That throttle body is alot bigger.
Old Dec 24, 2018 | 08:41 AM
Mark V8's Avatar
Mark V8
Looks good mate.
How did you increase capacity to 2.5 and what kind of power does it make?
Old Dec 24, 2018 | 11:26 AM
Danijel4x4's Avatar
Danijel4x4
We were ordering custom pistons so we ordered bigger and bored cylinders
At 1.2 bar 365 HP
Throttle body is from BMW 535/735 that's why it's bigger
Old Dec 26, 2018 | 07:06 AM
Danijel4x4's Avatar
Danijel4x4
One thing that you might like
Old Dec 26, 2018 | 09:07 AM
Mark V8's Avatar
Mark V8
Nice job on the electric window mods - what parts did you use ?
I suspect the cylinder walls are paper thin after boring out to 2.5 litres!
That's a +4.0 mm rebore
Old Dec 26, 2018 | 10:40 AM
Danijel4x4's Avatar
Danijel4x4
WOW...didn't quite get your calculation but this is not cossie 2.0, it's 2.3 engine....it has bigger stroke then cossie (77mm cosworth, 91mm 2.3 scorpio)
Electric window....ufff, i wanted it so badly ....one day i was driving company car (Punto MK1 "DIPLOMAT") and it had one touch power window for driver side...little looking around and i founded their simple solution:
Only thing is that you have to use one module for one window...
Old Dec 26, 2018 | 10:57 AM
Mark V8's Avatar
Mark V8
2.3 is 89.6 bore x 91 stroke
8.96 / 2 = 4.48 so (4.48x4.48) x 3.142 = 63.061 cm2
63.061 x 9.1 = 573.857 cc x 4 = 2295.4cc
You would need a bore of 93.6mm to get out to 2.500cc
9.36/2 = 4.68 so (4.68x4.68) x 3.142 = 68.817 cm2
68.817 x 9.1 = 626.237 x 4 = 2505cc
2.3 has the same bore centres as the 2 litre and there is not a lot material left for boring out.
Brave decision !
Old Dec 26, 2018 | 11:02 AM
Mark V8's Avatar
Mark V8
Does that relay work with a timer or is it current sensing mate?
Old Dec 26, 2018 | 11:23 AM
Danijel4x4's Avatar
Danijel4x4
O.k...maybe it's 2467....2.5 sounds better than 2.46 ....i just know that we did not go to much and that it has enough walls left
relays do not have it's own timer...you have to put one extra if you want it to work that way
Old Aug 17, 2019 | 08:55 AM
Danijel4x4's Avatar
Danijel4x4
If anyone is interested, car is for sale...everything works and runs fine. Right now car is AWD but i give with car one RWD gearbox with all parts just to bolt on (made for DYNO purposes) and TWO (2) more gearboxes 4x4, one more front diff and one more rear diff. I have one more 2.0 DOHC (whole car) that i give with this one if you want...and whole lot of parts
I think 6000€ is a fair price
the1da
83
Aug 27, 2017 12:45 PM
tomiii
12
Aug 18, 2015 08:40 PM
NoGutsNoGlory
Ford Classics & Vintage
May 19, 2014 10:17 AM
T28 RST
Nov 18, 2012 04:53 PM
toff
15
Sep 14, 2007 07:07 PM
