Rs turbo fuel relay
Old Nov 26, 2018 | 04:14 PM
E83w vince's Avatar
E83w vince
Default Rs turbo fuel relay
Hi all
As of my last post I've got a question about the fuel pump relay does anyone know what number is for the trigger?
I've had everyone and their grandad touching and giving advice the pump will not prime.
anyone?
Old Nov 26, 2018 | 06:42 PM
TommysKeeper's Avatar
TommysKeeper
S1 or S2? S1 - Try bridging the relay (instructions in Supplementary handbook). If this works then your relay is kaput!
Good Luck.
Cheers, John
Old Nov 26, 2018 | 06:49 PM
E83w vince's Avatar
E83w vince
Default Relay
Hi
I bought a new relay still no power to the pump if I put a live to the pump it works what I would like to know is what wire does what on the relay then I might have a chance
Old Nov 26, 2018 | 07:34 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
send a pm with your number i`ll text ya, then we will arrange 5 mins when you have a multi meter or test light
Old Nov 28, 2018 | 10:55 PM
martysmartie's Avatar
martysmartie
The ground is switched via the ECU (S1's had a timer relay), so assuming this is ok there will be a supply missing or a wiring problem.
I assume this is a S2?
Martin
Old Nov 29, 2018 | 09:40 PM
E83w vince's Avatar
E83w vince
Martin
yes mate its a s2
it has a constant feed to the green and red wire and also a live feed to the black
JWHUBBARD
Apr 4, 2013 05:30 PM
kieronescort
Jan 12, 2010 10:02 PM
haz87
Oct 18, 2008 08:36 AM
jonesymk2
11
Jan 19, 2008 05:16 PM
Gartrac Mike
Feb 7, 2006 05:16 PM
