3dr power steering pipes loose?
Old Nov 11, 2018 | 09:09 AM
RSWilson's Avatar
RSWilson
Default 3dr power steering pipes loose?
Hi folks,
Quick request for help.
My 3dr steering rack has a wobbly pipe but I don’t know why. The wobbly end is where the various pipes gather, near where the column goes into the rack. It seems the the pipe concerned (the larger of the pipes in the photo) is a push fit and is then held in place by a retaining clip style item which is secured by a 10mm bolt which seems tight.
Can anyone who has experienced this item please advise if it should wobble and if not what looks wrong please? Is it missing a collar or something?
Thanks
Larger pipe is loose
Old Nov 11, 2018 | 10:30 AM
Caddyshack's Avatar
Caddyshack
Yes, they do wobble. They have a rubber seal under there and the plate on top stops it popping out, nothing to worry about.
Old Nov 12, 2018 | 12:14 AM
RSWilson's Avatar
RSWilson
ah that helps, thanks!
Big Will_
24
Mar 2, 2011 11:07 AM
c0ss1e9i6
Aug 24, 2005 07:23 AM
c0ss1e9i6
Aug 23, 2005 09:05 PM
