3 door cosworth wheels
Old Oct 12, 2018 | 11:50 AM
dal3door's Avatar
dal3door
Default 3 door cosworth wheels
Hello been doing load of research on the net about what 17in wheels will fit on my car without cutting back the archs and they also have fit over 6 pots brakes with 335mm discs at the front and 4 pots with 328mm discs on the rear what I think I have come up with that will also look good as well is
7.5j x17 with an offset of et35 with tyres of 205/40/17 on the front
8.5jx17 with an offset of et30 wth tyres of 235/40/17 on the rear
I you own a 3 door cosworth do you think these would fit or even better what do you run on your car
thanks very much for any help given
Old Oct 22, 2018 | 03:23 PM
R4N SS's Avatar
R4N SS
pretty sure most comp mo's will fit
maxturbo
Sep 22, 2009 10:24 AM
zvhrst
Jul 2, 2009 08:00 AM
cossymad
Ford Escort RS Cosworth
May 27, 2005 04:03 PM
ben11
Mar 22, 2005 04:44 PM
